REVIT SURFACE PATTERN
default_unknown
default_unknown
Hi may I ask on how to remove the highlighted lines in the picture below. This is a surface pattern.
This is what it looks like on the properties.
Thank you
Are you sure the lines are coming from the Graphics Tab Fill Pattern and not the Appearance Tab settings?  Doesn't look like you have a Fill Pattern assigned.
edit: actually, I don't know what's going on. Post the file.
hugha
You need a pattern specification that does not contain or inject those vertical lines, such as this one built assuming a block size of 75x600mm:
; Written by HatchKit 4 Standard Edition
; HatchKit 4 Standard Edition (c)1990-2020 Cadro Pty Ltd
; www.hatchkit.com.au/
;-Date : 2020-12-17
;-Time : 15:40:10
;-HatchKit 4 Version : 4.0.9.2894
;%VERSION=3.0
;%UNITS=MM
*Entities,DXF Entity Section
;%TYPE=MODEL
0,0,0,0,75
90,750,75,-450,150,75,-1125
90,600,0,-450,150,75,-1125
90,150,75,-450,150,75,-1125
90,0,0,-450,150,75,-1125
hth,
Hugh Adamson
www.harchkit.com.au
Good eye @hugha. I see now. But why isn't Pattern displayed in Preview? Scale maybe?
default_unknown
It works! thanks!! I wanted to appear the pattern also when I render, how to do it?
default_unknown
because the color is set to white?
syman2000
Rendering won't show hatch, you have to add those hatch image to the material. I just took a screenshot of your hatch pattern
Afterward create your material and click on image and select the image above
When you click on realistic and you will see the material show. Now you are able to render.
