Today, after a Win10 update Revit began to act very slow. Even when im typeing text on a dimension line, it takes a while, and the loadingbar in left buttom corner, is working like loading big changes.
I tried to uninstall the update, but it dosent work.
Any suggestions, how to work this out?
Do some troubleshooting to see if it really points to the windows update.
-Check with a fresh project.
-Check with different Revit versions.
-Check on a different computer that also has been updated and see if the problem is the same.
If it is caused by the win10 update then I expect it would impact lots/several users. Then it will be up to Microsoft or Autodesk to resolve this (hotfix?).
Louis
Please mention Revit version, especially when uploading Revit files.
I did what you suggested. Is not slow anymore, but dont know which part that worked.
