Revit Steps in Topography
Matthew.Alder
Message 1 of 8
Matthew.Alder
I have a survey which has flat rocky steps which I'm trying to import into Revit as a Topography. Problem is Revit smooth's the surface out and steps disappear into the topography surface.
Is there a way around this?
Thanks in advance
Replies (7)
Message 2 of 8
Did you create the topo from a DWG or a point file?  If a point file than the steps should remain, if a DWG then I can see why Revit smooths the geometry out.  If you don't have a point file then you can add building pads to the topo in Revit to replicate the steps, or manually copy a set of points down or up to create the steps (but it can be difficult if the site is complex).
Message 3 of 8
Matthew.Alder
It is a drawing file (DWG). It has points in it along with survey lines and steps outlines. If this what you mean?
I may have imported drawing file without the points. I will give it another try, otherwise I will replicate the steps as you say.
Message 4 of 8
A point file mean a text file, CSV or TXT format.
Message 5 of 8
Matthew.Alder
Oh ok, can a CSV or TXT file be created from an AutoCAD file? I don't have Civil 3D.
Message 6 of 8
No. AutoCAD can't generate point files.
Message 7 of 8
ennujozlagam
hello, Don't mind to check your autocad file if your survey plan has X and Y value. thanks
Message 8 of 8
Smiley Wink
