I am finding it impossible to build steel frame is Revit 2017. I tried using sweep function with an import of the UB profile family but it doesn't show the beam properly. The filleting disappears!
So I tried to build the frame I need using beams and joints. I need to create a square frame and Revit allowed for 3 joints and refused the 4th for some reason. What am I doing wrong? I attach the file with the relevant frame.
If anybody knows how to solve this I would be grateful.
If you know of video tutorials for Revit steel framing techniuqes please post the links.
Thank you!
Gelöst! Gehe zur Lösung
Gelöst von artejon. Gehe zur Lösung
Set Start Extension and End Extension of adjacent beams to 0 in properies, use Trim/Extend (beams will meet), now use Beam/Column Joins and pick a small arrow of vertical (on screen) beam and they will join as you want.
