Revit Stairs
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
1022 Aufrufe, 8 Antworten
Revit Stairs
Hi I am trying to close up my rounded stairs inside with a wall like the image attached. Ive attached the stairs as wall. Please assist me how I would go about doing so. Thank you!
8 ANTWORTEN 8
Nachricht 2 von 9
constantin.stroescu
als Antwort auf: Anonymous
I think I'll use in such a case a Mass ( in Place Mass - using Reference Points) and then a Wall by face...the result will be as in my screenshot:
Constantin Stroescu
Nachricht 3 von 9
constantin.stroescu
I've made a screencast that shows how it works....
Constantin Stroescu
Nachricht 4 von 9
als Antwort auf: constantin.stroescu
Wow looks very complicated. Thanx so much!
Nachricht 5 von 9
constantin.stroescu
maybe this way is a little more simple,and can be done for helix shapes:
Constantin Stroescu
Nachricht 6 von 9
constantin.stroescu
or , in a more classic way ,using Wall cutted by Void  Model in Place Component:
Constantin Stroescu
Nachricht 7 von 9
Can we see a few more methods please :leicht_lächelndes_Gesicht:
Seriously though, I like a combination of the 1st and the 2nd.
Nachricht 8 von 9
BIM.Consultant
Actually it's simpler than you think. All videos above are using different type of stairs then the one you have attached; and in the case of "your type" of stairs, above methods will be time consuming.
The very simple way is to use the standard wall tool within Revit, and align the top of wall to the bottom of each step. So I made the wall as small segments. Check attachment.
Nachricht 9 von 9
als Antwort auf: BIM.Consultant
Thank you so much! This is a great help! I think I will go with the last option.
