Revit Stairs
1 ANTWORT 1
Nachricht 1 von 2
470 Aufrufe, 1 Antwort
Revit Stairs
Hi I am trying to close up my rounded stairs inside with a wall like the image attached. Ive attached the stairs as wall. Please assist me how I would go about doing so. Thank you!
1 ANTWORT 1
Nachricht 2 von 2
Kimtaurus
als Antwort auf: Anonymous
First you draw the walls underneath the staircase.
For the straight wall you edit the profile of the wall.
The curved wall is a bit trickier. Here you need the ceate a component by Model-in-place. Draw a Void Sweep Blend along the curve of the wall. And cut the wall with this void before finishing the component.
I also tweaked your staircase a bit, to resemble your picture.
I can't post the file itself, as I'm working in Revit 2016.
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
