I was pleasantly surprised when I discovered the Site Designer feature for Revit. Even more when I read some promising term: LandXML. However, that standard does not seem to have gained much traction.
My objective is to add a Street (Elm) and a Lincoln Continental to my 3D Model of Dealey Plaza.
Need to get the most accurate topographic data as possible. This is what I have:
https://maps.dcad.org/prd/dpm/?parcelid=000010001301A0000
If the Revit/LandXML combo are not ready for that tall order, what else could I use?
TIA,
-Ramon F. Herrera
JFK Numbers
Gelöst! Gehe zur Lösung
Gelöst von borakin1. Gehe zur Lösung
Hi;
You have a lot of options, one of them is "REVIT SITE DESIGNER". Autodesk's own extension is good for site modeling. The other is "DYNAMAPS" with which you can use "REVIT - DYNAMO" very useful, but hopefully not for TURKEY. i hope to it work in your country. Last one is "Ge-Terrain" its paid add-on but works fine, its give 0.5-2 meter accuraccy from google maps.
To automatically import topography;
@borakin1 wrote:Hi;
I hope it works in your country. Last one is "Ge-Terrain" it's paid add-on but works fine, it gives 0.5-2 meter accuracy from Google Maps.
Thanks, Borakin.
I am located in Dallas, Texas.
I was about to purchase Ge-Terrain ($28, my kind of price), but it seems to be only for Revit 2019?
Ge-Terrain at the Autodesk Store
One more question: I can easily get satellite images of Dealey Plaza, and look at them in my Revit. However, I want to broadcast those images to a number of non-technical people. What kinds of media can I send them? A URL? MP4?
TIA,
-Ramon
JFK Numbers
Ge-Terrain 2019 at the Autodesk Store
The version of Ge-Terrain for Revit 2020 may be purchased here:
Ge-Terrain for Revit 2020 at the Autodesk Store
Important Notes:
(1) You need to have a developer account at Google (same used to put Google Maps in websites)
(2) You have to enable 3 Google Developer APIs.
-Ramon
JFK Numbers
Important Notes:
(1) You need to have a developer account at Google (same used to put Google Maps in websites)(2) You have to enable 4 Google Developer APIs.
-Ramon
JFK Numbers
None of that is documented.
-Ramon
JFK Numbers
