Revit shuts down while rendering in V-RAY
2 ANTWORTEN 2
Nachricht 1 von 3
249 Aufrufe, 2 Antworten
Hello.
I have a problem. I have a new work computer (i7-10700k, rtx 2070, 16GB RAM 3200Hz) and when I try to render a more complicated 3D view Revit just shuts down after like 1 minute of rendering (without any pop up window). I tried changing rendering settings from progressive to buckets, setting quality to low (resolution is at 942x600). What else could I try?
2 ANTWORTEN 2
Nachricht 2 von 3
ennujozlagam
als Antwort auf: Anonymous
try to install latest updates like window OS, graphic card driver and latest updates from autodesk and see if helps. thanks
Nachricht 3 von 3
ryley.g.h
If you're using a central model try and disconnect it and render. I've had similar problems while trying to render inside central models in the past.
