Hello experts,
I have set up two sheets in my Revit Project but one just wont print. I noticed that the viewport on this particular sheet zooms out to include the project survey point. Unfortunately, I can not seem to crop it to just the plan I want to plot. The sheet of the upper plan which does not stretch to the survey point, prints all alright.
Could the zoom out to the survey point be the cause of a sheets failure to plot. If yes (or not) how can I control the extent of a viewport on a sheet. And if not, why is the other sheet that does not zoom to the survey point plot? What could be the cause of the plot failure?
See a snip of the zoomed out sheet.
Gelöst! Gehe zur Lösung
Gelöst von Mark.Ackerley. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Did you try scopebox and use that to crop the view?
Hey,
As the guys have noted... Apologies if you knew these already, if not, maybe this helps explain in more detail...
1. Un-Check the Visibility Overrides > Site > Survey Point visibility(assuming you don't have a view template applied)
2. Check the View > Crop Box, to see if it correctly set (it might be defined by a scope box) properties...
Hope that helps,
Mark
It was all about turning off the survey point in the visibility graphics.
