Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Revit Sheet Schedule wrong filtering
EgorRRA
EgorRRA
Hey all revit masters,
I have an issue projecting a proper numbering in the sheet schedule. By logic, sheet numbers should either increment or decrement, and here I have an issue where it doesn't follow the increment order and it goes as 01,02,03,05,04... I tried looking into filtering options and having other guesses, but nothing is in my knowledge to find a solution to this issue and making the sheet schedule going the proper order like this: 01,02,03,04,05... If you know what could be the issue, please let me know. I will leave a screenshot of the schedule so it would be more clear
Replies (9)
denis_borodin
Send your file.. or at least a screenshot
Denis Borodin, BIM Manager. LinkedIn
EgorRRA
Oh, sorry, I thought I attached a screenshot.
Here it is
denis_borodin
It looks like you put sheet name in column, but sort by sheet number. Hard to say
juliar123
Can you send an image of what you are sorting by?
What is the schedule sorted by? Any hidden columns?
EgorRRA
The sorting and grouping is done with folders and phases, it doesn't really specify on drawing number. You can see it in the screenshot
denis_borodin
Impossible. Remove all 3d objects and views from your model (if you have some confidential data), keep only sheets and sheet schedule and send here the file.
juliar123
What year of Revit are you using? I'm unaware of any bug that would do this. The only possibility would be if any other sorting categories are pushing it to go above the sheet number. Look at those values.
If nothing else, make a new schedule and only sort by sheet numbers and see if that shows up correctly, then slowly start adding the other filters.
Here it is
Turn on the column header so we can see what is what.
