Revit Sheet covering added detail view
3 ANTWORTEN 3
Nachricht 1 von 4
brobes05
241 Aufrufe, 3 Antworten
My Revit sheet is covering an added drafting view.
I have created a title block family with a Tiff on the sheet. Thus, the sheet seems to be covering the inserted view. See Image.
Thank you in advance,
3 ANTWORTEN 3
Nachricht 2 von 4
Basam.Yousif
als Antwort auf: brobes05
Hi!
If you switch the TB to one from another family (not type)  OR temporarily delete it, will the view show correctly?
If so, you might have your answer. This TB has something causing the masking and you need to remove it.
You can message me the TB and I check it out for you, if you'd like. I'm on tech support duty today :leicht_lächelndes_Gesicht:
Nachricht 3 von 4
brobes05
als Antwort auf: Basam.Yousif
Thanks for your reply!
It turns out that the .tiff with a white background simply covers the whole sheet. I used a .png instead. Simple fix.
BTW, what is a TB? I may be ignorant.
Thank you again.
Nachricht 4 von 4
Basam.Yousif
TB = Title Block :leicht_lächelndes_Gesicht:
And, No. You're not ignorant.
