I would NOT recommend it on a LAN. All it adds is complexity.
A good LAN with a high quality server with fast CPU and lots of RAM,dedicated to hosting Central Files, gigabit hub/switch, good ethernet cards on workstations (also with good specs) and you are good to go.
RS was intended for multi-office collaboration with a WAN. It has largely been replaced by C4R / BIM360.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
