revit server administrator is blank (RNS file checked)
8 ANTWORTEN 8
Nachricht 1 von 9
1559 Aufrufe, 8 Antworten
hi experts,
i have a problem about the revit server administrator.
it is working fine with synchronize file and save on revit server. when i try to open the administrator page first time,  the page asked me to install microsoft sliverlihgt,  after installed the plugin and reload, the page goes blank now.
I checked the RSN file on the server and client both, so i am sure it is in the correct situation, then i have no idea now.
any tips about this?
many thanks for you guys first.
8 ANTWORTEN 8
Nachricht 2 von 9
DarrenP
als Antwort auf: Anonymous
may want to check again
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
its pointing to a rsn.ini problem
DarrenP
Nachricht 3 von 9
als Antwort auf: DarrenP
As I said  I ALREADY CHECKED ALL RSN.ini file is in the correct path and correct ip (see attachment), and it doesn't show any error message when I open the revit server administrator page, the page still is a BLANK page when I try to access, but the synchronize function is working fine, thank for replay anyway.
Nachricht 4 von 9
kristina.williams.22
We have been having this same problem for years and haven't had luck finding a solution.  Seems related to the combination of profile and workstation used to access the page.  For instance, User A can access on Workstation B, but not on their own Workstation A.  On the other hand, User B can access on Workstation A, but not on Workstation B.   Our IT team has been looking into it, starting with a Silverlight issue, but I'm not sure it's related to that either.
Have you had any luck since this post?
Nachricht 5 von 9
Nachricht 6 von 9
loaynali
I have same problem in revit server administrator 2021
Nachricht 7 von 9
als Antwort auf: loaynali
did you read any of the links that were given already?
Nachricht 8 von 9
loaynali
Yes, I read it and try to solve problem and not work with revit server 2021
Nachricht 9 von 9
in2click
looks kinda stupid but:
i've just installed RS2019 on my winsrv2022, configured everything as usual and got the same at several different virtual servers:
/revitserveradmin2019/#/FilesPage was white blank (browsing locally, remotely, FQDN or IP doesn't matter - and with Revit itself working fine - browsing contents of RS, syncing and so on )
what i did:
1- deleted my rsn.ini
2-rebooted
after this /revitserveradmin2019/#/FilesPage has some content (title, buttons etc.) but target server is not listed on the left side
3- now i put back again rsn.ini with FQDN of my win server and rebooted
after this everything goes fine in all over 10 of my installations
i just hope it's not a real solution
