After 15 minutes of googling and searching the Autodesk site, I can't find a download link to Revit Server 2021. Is this yet to be released or can someone post the link? In general, Autodesk should make it way easier to find Revit Server download files for any version, even previous versions are not easily found IMO.
Gelöst! Gehe zur Lösung
Gelöst von huotger. Gehe zur Lösung
Gelöst von DarrenP. Gehe zur Lösung
its part of the Revit 2021 installation see below
DarrenP
As with previous releases, the installer for Revit Server is included in the full Revit installer. On the initial page of the Revit 2021 installer, select the Tools & Utilities option and this will lead you to the Revit Server installation.
Thank you! In the past I've always just used a standalone installer for Server. I didn't think to check the full Revit installer. Good to know.
As in past years, Revit Server 2021 can be found directly on AKN at:
Running the RS 2021 install from the download link you provided says this is a Preview Release.
The reason I don't install from the Revit installer is I can't change the installation drive from C:\...to D:\...
The separate installer allows me to change that location
Any thoughts on this? Is there a final release version coming?
-Bob
Thank you for reporting this issue, it appears that the banner image was not changed. We will have a look and rectify the download executable. The file posted is the final 2021 version.
I had noticed the Preview Release banner as well but a couple weeks later we haven't had any issues with it.
