Revit Server 2019 | no Revit Server Network icon in "Save As"
LOESCH_PK
LOESCH_PK
Hi there! I've set up a Revit Server 2019 on a Windows Server 2012 R2 machine, got through all steps pre- and post configuring, but there's still a mayor issue. I cannot save anything to Revit Server Network. It is visible from all dla workstations, the RSN is visible in a "Open" window... but it isn't in "Save As" window...
The RSN.INI file had been installed on all machines. The IIS has all rights to save/modify the catalogues...
What can be wrong?
infoN3DBR
I am having the same issue with Revit Server 2020. Did you get to the bottom of it?
infoN3DBR
