REVIT SERVER 2017 error
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
aenkhod
1413 Aufrufe, 5 Antworten
Server 2017 V1 installation on Windows Server 2012 - WORKING FINE.
        1. C:\ProgramData\Autodesk\Revit Server 2017\Config - CONFIGURED
        2. AdminService2017 - basic disabled, anonymous enabled
http://localhost/RevitServerAdmin2017 or http://RevitServer/RevitServerAdmin2017 - ERROR
 Revit
Revit Server Administrator is not installed on the server you are trying to access. Use different Revit Server name in address bar of your browser and try again.
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: aenkhod
Nachricht 3 von 6
Lance.Coffey
I've notified a Moderator regarding moving this thread to the appropriate board.
Regarding the issue with Revit Server Administrator, I would suggest checking the steps in the following article (in particular make sure that the Admin Role is enabled):
How to check Revit Server for basic functionality
Lance Coffey
Technical Support Specialist
Nachricht 4 von 6
i not setup revit 2017. hepl me
Nachricht 5 von 6
Lance.Coffey
als Antwort auf: Anonymous
@Anonymous From your post, I'm not clear if you are seeing the same issue that @aenkhod reported.
If you are seeing the same thing, I would suggest trying the same solution (How to check Revit Server for basic functionality) and if a resolution is not found reply with the results.
However, If you are having a different issue, I would suggest creating a separate thread to describe your issue (make sure to differentiate between Revit issues and Revit Server issues, also if your issue is with installing Revit we have a separate board (Installation And Licensing) to post such issues.
Lance Coffey
Nachricht 6 von 6
aenkhod
Please print screen your desktop let me see.
