Dear all,
I am trying to unselect a specific element from my mouse selection that I am not able to do so by using the filter, as some of the type of element I want to select, and a specific few I would like to deselect, and they are all in close proximity from each other.
In the way that when you hold ctrl and then click on new elements to select, is there a way that I can do this in reverse, to deselect elements?
Thanks in advance! Nina
Gelöst! Gehe zur Lösung
Gelöst von stevensonJQWEF. Gehe zur Lösung
oops, ive solved it, simply with the select from left to right vs right to left function ![]()
@stevensonJQWEF wrote:In the way that when you hold ctrl and then click on new elements to select, is there a way that I can do this in reverse, to deselect elements?
Shift+click
