Revit section of Enscape objects
4 REPLIES 4
nelson_rios
307 Views, 4 Replies
Hi, when I make a section in Revit I have a linked topography that contains trees from Enscape assets, when I make the section the trees that should disappear are still visible. The linked file is also from Revit, the problem are the trees from the assets library.
Is it possible to solve it.
4 REPLIES 4
in reply to: nelson_rios
It's happening because they aren't Cuttable Families.
Help | About Cuttable Families | Autodesk
...plus, they are RPCs.
nelson_rios
Thank you barthbradley for your reply.
I was doing some research on the problem and I did see that there are objects from some families that are not cuttable. But I can't find the way to transform them into cuttable, in the family options it doesn't appear. Is it possible to do it.
Greetings.
You can change a Families Category, but that won't work with RPCs.
nelson_rios
in reply to: barthbradley
Forma Design Contest
