Hey there, I am kinda new to Revit and I do not know how to do this:
I need to add Quantity type (typ plochy) 2 more times to the columns. There must be 1 ceiling surface, 1 wall surface, 1 floor surface, and the circumference of the room, And the data ( m2, m) should be beneath a corresponding column. For example
WALL SURFACE; FLOOR SURFACE; CEILING SURFACE; ROOM CIRCUMFERENCE
XX m2 XX m2 XX m2 XX m
+ there should be a material next to the area.... so something like this:
MATERIAL, CEILING AREA; MATERIAL, FLOOR AREA;
STUCCO - white, 52 m2; WOOD FLOORING, 52m2
etc...
If you can help, I would appreciate it!
As much as I searched for a video on formatting schedules, I was not able to find one that is useful...
How can I format the table from this into something like this
I need to put the rows into columns and divide the data...
