Revit Schedule formulas - specify decimal point
6 REPLIES 6
Ian_H
478 Views, 6 Replies
Is there a way to specify the decimal point in a revit schedule formula?
I found a post about revit family formula and it had a way of multiplying and diving by 10 to the exponent that matched the decimals you wanted, but it didn't seem to work.
Labels (3)
6 REPLIES 6
mhiserZFHXS
in reply to: Ian_H
Can you give an example of what you want your end result to be?
To get the 10 to whatever power, you should be able to put in "...*10^(some parameter where you enter in the power to multiply by)"
Sean_Page
in reply to: Ian_H
Do you mean rounding it?
Ian_H
in reply to: Sean_Page
Thanks, I feel dumb now for overthinking it and forgetting about that.
mhiserZFHXS
in reply to: Ian_H
Rounding and multiplying by a power of ten are two very different things... Which one did you want?
Ian_H
in reply to: mhiserZFHXS
This is what I was referring to -->
This is from this forum thread -->
Work sites
mhiserZFHXS
in reply to: Ian_H
Ah. I mean, they're mathematically correct, but not with the rounding function. What @Sean_Page said would get you there.
