Revit Schedule Cell Alignment
6 ANTWORTEN 6
Nachricht 1 von 7
panastos
362 Aufrufe, 6 Antworten
I have added some cells to the title area above the data in my schedule, but the edges of the cells do not align with the data columns and try as I might they refuse to align. Is there some trick to this?
(Revit 2024)
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: panastos
got a screenshot?
Nachricht 3 von 7
panastos
You can see if you look closely the vertical lines are not aligned, where the grips are. I can drag the lines but they won't align perfectly.
Nachricht 4 von 7
TripleM-Dev.net
Hi @panastos,
There's no alignment between the user added cells in the title and the data columns.
Maybe you meant to group data column headers? Those align with the columns.
- Michel
Nachricht 5 von 7
panastos
als Antwort auf: TripleM-Dev.net
Right thanks that is the best way to do this, still it'd be nice to be able to align those cells, I'm not sure why you can't
Nachricht 6 von 7
TripleM-Dev.net
The "Spacing, S1 (in, O.C.)" column etc, that isn't the column header?
This layou can be made with the Headers (rename title of headers) and then group them for the "Stirrups (ZONE 1)"  etc...
Nachricht 7 von 7
handjonathan
Hi @panastos
Thanks a lot for posting your question to the forums!   Has the solution suggested by @TripleM-Dev.net  helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
