I have a revit file that was modelled and sent over to me from a colleague. If i save this file onto my desktop on Revit 2023, will Revit show my colleague's name/username via the Show History/ Manage models section under the Collaborate tab. The colleague never produced the model under the cloud, so I'm assuming his name cant be traced.
Secondly if i select "Save As" as a saving option, and replace an existing file will it still show the model history of the existing file before it was replaced by my colleague's file or will it only show the date of the saving
Hope that makes sense
Gelöst! Gehe zur Lösung
Gelöst von 20079741. Gehe zur Lösung
Just open the file with Detach from Central and Detach and Discard Worksets checked.
Ok so selecting detach from central would stop the file from ever being traced to the original user
Say I do the above and then I go on to select "Save As". With the Save As option set, I replace a past file in my desktop and save as that file name. So I've replaced the past file with the file my colleague gave me and selected "Save As". Will Revit still allow me to retrieve previous history files/ save history
Hey Rob
My laptop crashed few days ago so I'm having to submit work under a deadline. I haven't had the grace of more time
The work me and my colleague is similar albeit minor adjustments
Plagiarism and/or cheating should not be supported in these forums.
Sounds like you're trying pretty hard to cover up something you're doing that you are also trying to say isn't that big of a deal.
Not sure if this is for work or education, but either way, perhaps you should have just told your boss/teacher/professor that your laptop crashed when it happened, instead of waiting until what I assume is the last minute to cover it all up.
