@Anonymous wrote:
I was just curious to know if a build up tutorial, or manual existed for the Revit Sample Project, for Revit 2017?
Perhaps a silly question, but certain objects in the model could be interesting to know a bit more about.
Steffan L.
There is not a tutorial showing the building up of any of the sample models. There was at one time, but they are no longer published. The sample models are supposed to give an example of most of the standard elements you would find in a typical model so you can try and reverse engineer them if need be..
Jeff Hanson
Principal Content Experience Designer
Revit Help |
