Does anyone knows a way to change the volume of a room so that it is not rectangular. I want to subtract from the room volume the volume of some trapezoidal beams.
...wait a minute. You mean you don't want the Room's Upper Limits bound. Remove the Room Bounding Property from the upper element and readjust the Room's Top Limit Offset as necessary.
Hard to understand exactly what you want to do. I'm now thinking that Room Separation Lines might get you to where you want to go - wherever that it.
Change room computations to volume/area, increase the room upper limit, model elements above as room bounding elements.
