I have installed "Roombook Areabook Buildingbook 2016" plug in. The problem is that after we installed plug in, only area and building books appear in Quantitfication tab.
We tested on other companies machines and the same happens everywhere.
Any advice?
Regards
Predrag
Hello Predrag Jovanovic,
My name is Giosuè, I am a Revit specialist.
Click HERE and please carefully review this article which contains a suggestion that may help us to resolve this issue. The article uses RVT 2015 and Germany as example, however you can adjust these values to your personal case. The suggestion should be valid for Roombook and Buildingbook, and not only for Areabook.
Test it and please let me know if the issue persists. In case I don't hear back from you within 2 business days, the case will be archived. However you can still post at anytime your comments and thoughts in this thread.
