We are working on a renovation project that is split between 4 phases in Revit 2015. We received the room numbering system from our client while in our second phase, which we then implemented into our model. I am attempting to copy and paste about +350 of these rooms into our other 3 phases while maintaining the exact room numbers. I've been on different forums where they state that the room numbers should remain the same, however, Revit is renumbering all of my rooms when I copy paste them. I've tried several methods already, all which fail. I'm out of options and very frustrated.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
That's exactly the issue we had. Turns out, our schedule had the "not placed" rooms hidden and once those were deleted out the room copy paste worked as needed. Thanks!
