Revit Room Boundaries And Tagging ISSUE: there is really something wrong
6 ANTWORTEN 6
Nachricht 1 von 7
LanggamanXavierMassed
574 Aufrufe, 6 Antworten
Hello everyone! I cannot make a wall-defined room even though it seems properly enclosed when i used the "room" command. As seen in the image, under the "place room tag modify" mode, the T&B room highlight looks wrong but the other room seems to not have a problem, it couldn't seem to recognize the walls.
Thank you! I'm a newbie by the way.
6 ANTWORTEN 6
Nachricht 2 von 7
RobDraw
als Antwort auf: LanggamanXavierMassed
Have you made the walls "Room Bounding" in the properties?
Rob
Nachricht 3 von 7
als Antwort auf: RobDraw
yes sir, the Room Bounding is checked in the properties
Nachricht 4 von 7
Anyways, It's working, thank you!
Nachricht 5 von 7
RobDraw
What did you do to fix it if it wasn't the room bounding?
Please share the solution so that others finding this thread might get some help.
Rob
Nachricht 6 von 7
Make sure the Base Offset is not > 0.
Nachricht 7 von 7
als Antwort auf: ToanDN
...but, if Base Offset is >0, change the Level's Computational Height to equal the offset.
