Revit Roof Question
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
503 Aufrufe, 5 Antworten
Revit Roof Question
I have a small project that I am having trouble with the roofs. I have searched the forums and can't find a similar problem that has been solved. I have a roof that has different heights and pitches. I would like move one side of the roof forward and cut the part of the roof it will run into up towards the peak. This all happens on one side and the other side is left alone. I hope my picture of what I want makes more sense. If what I have completed is wrong or you can provide a better way of doing this, please let me know.
Thanks for any info you can provide.
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
It is pretty straight forward.  Just edit the boundary lines of these roofs and move the edges to where you need them.
Nachricht 3 von 6
als Antwort auf: ToanDN
Hello and thanks for the response. Is there any way you can give some instruction on this process? When I edit the footprint it gives me several error messages (can't keep wall and target joined, can't regenerate family roof cut, etc...) and highlights most of the model.
Nachricht 4 von 6
Nachricht 5 von 6
Nachricht 6 von 6
Thank you, That did it.
