Revit Roof Drains and Tapered Insulation
11 ANTWORTEN 11
GELÖST
Nachricht 1 von 12
jhafnerYWHJW
2003 Aufrufe, 11 Antworten
I am trying to install overflow drains into the slope of a tapered roof, but because its built up with insulation, the drain attaches below the insulation to where the host roof would be. I've tried to edit the family but haven't had any luck. Anyone else run into the same problem?
11 ANTWORTEN 11
Nachricht 2 von 12
ryley.g.h
als Antwort auf: jhafnerYWHJW
Before you place them go into the architecture tab in a 3D view, and press set workplane, choose select a plane, then select the top surface of the slopped insulation. Once workplane is set, try to place them and maybe that will work!
Nachricht 3 von 12
jhafnerYWHJW
als Antwort auf: ryley.g.h
It still wants to host itself to the roof since the surface is part of that roof.  I think its just how the family is made to always attach to that
Nachricht 4 von 12
Doesn't sound like it is a hosted family.  If not, uncheck "Always Vertical" and check "Work Plane-Based" in the family. Then place on the face of the roof surface in the Project.
Nachricht 5 von 12
jhafnerYWHJW
als Antwort auf: barthbradley
I can uncheck always vertical but I don't see the other property
Nachricht 6 von 12
Because it's a roof hosted family.  What is your roof build-up?  It's not a roof obviously.
Nachricht 7 von 12
ryley.g.h
That looks roof hosted, is the slopped insulation an actual roof?
edit- I just slapped one on a slopped roof, worked fine.
Nachricht 8 von 12
If it's not a roof, then the roof-hosted catch/grate won't mount to the surface of the build-up.  You could check "Share" and nest the Roof-Based family into a Face-Based family and put the Face-Based family on the surface of the build-up.  Or, you could convert the Roof-Based Family to a Face-Based Family. This takes some explaining. You interested?
Hey, found this for you:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/simplecontent/content/conve...
Nachricht 9 von 12
jhafnerYWHJW
It may have something to do with the variable insulation? I have sloped roofs and they work there, but when I slope the insulation the roof goes right through the drain. What do you think? I attached my roof and its properties
Nachricht 10 von 12
Out of curiosity, are these intermediate catches placed on a slope effective? Governed by code?  Seems odd to me.
Nachricht 11 von 12
jhafnerYWHJW
This worked best! It needed to be face hosted. Thanks all!
Nachricht 12 von 12
jhafnerYWHJW
They're just for overflow, the main drains are on 0 slope
