Revit ribbon tab reordering with plugins installed
0 ANTWORTEN 0
Nachricht 1 von 1
m.hampl
172 Aufrufe, 0 Antworten
I tried using the official reordering method of holding ctrl+draging the ribbon tabs. The issue is after every Revit restart i get all the plugins first in order and only then, my custom order of "vanilla" tabs as was mentioned in the forum post here: Revit Ribbon tabs out of order - Autodesk Community - Revit Products
Is there anything i can do to fix this bug or am i stuck to the base setting after resetting the UI.
All i want to achieve is moving my modify button to the firs position as it feels much more user friendly.
Any help with this would be greatly appreciated.
Matej Hampl
Tags (1)
0 ANTWORTEN 0
