Hello @Akunkinga,
As @ToanDN mentioned I think this issue is related to Windows View settings and scale.
You can also access the solution of the problem supported by visuals in the support article published specifically for AutoCAD below;
Ribbon is cut off at the bottom in AutoCAD
Let me know if you have more questions on this topic, otherwise please accept as a solution so that others can benefit from this information.
Best regards,
Gokcen Ezgi Sen
MSc. Architect - BIM Consultant
My screen was already set to 100% . I think the problem was that I changed the text size in windows from 100% to 110% so I had to change it back.
Its so fiddly trying to set up laptop as main screen and having Revit and Autocad on 2nd monitor which is much larger screen size.
I use recommended (by windows 11) on both displays but still find they are usually too small.
For example when using Autocad if I click on layers and the layers properties box opens on laptop , which is what I want, the text is tiny.
I will have a read on the link you sent .
Thanks for the tips
You can try to increase Windows Display Scaling to 125% but keep the text size at 100%.
I am on a desktop and I’m having the same issue with my ribbon being cut off. I have tried changing the scale (default recoups 150%). I’ve tried all combinations of scale and font size and nothing is changing it any advice?
