Hi all,
First apologies if this is a basic one, I googled the problem and didn't find a clear answer.
Is it possible to lock the position of the tabs? I have a few add-ins and this is scrambling the order of my tabs. I move them back to the order I want, then have to do it all over again everytime I open.
Hi @craig_SW
What version of Revit are you using?
Not sure why your tabs are moving around but you can remove unwanted tabs in File, Options, User Interface if this helps. Just untick the ones you don't want:
Thanks. I'm aware of all that. It's add-ins in the Ribbon that seem to override the order...
Not of much help but I do have the same problem. It is annoying that every time I open Revit the add-in tabs are on the left of the panel. I have been searching for an answer to this for a while and Autodesk doesn't seem to get aquantied
