Revit Rendering - Escape
mairh_tsek
mairh_tsek
I finished a project in which is with the coordinates and I want now  to render it. I download a free trial of Escape.
The problem is that when I start the escape I cannot see my building nowhere. Maybe because the long distance that I have. [ I have also link some dwg files that are enough big].
Is there anyone who use the escape and can help me?
Thank you in advance!
MostafaElashmawy
I think you mean Enscape.
Before running Enscape , make a section box around the area you want to render in the 3d view (Regardless how big it is).
In that case Enscape view will focus on that area only.
Otherwise, try to clean your revit model.I'm sure you have some item very far from the render area.
Mostafa Elashmawy
a00812364
Source: Enscape User
  1. Create a Revit Camera like you would usually
  2. Project Browser > 3d Views > (Created View: Default 'View 1')
  3. Visibility / Graphic Overide
  4. Turn off Imported CAD files in imported categories (lessen the clutter)
  5. Enscape Tab
  6. Select 'View 1' in the drop-down (default is 3D)
  7. Run
Enscape camera should spawn closer to your Revit model.
