Many thank you for your time.
I'm having some trouble while creating walk-through in realistic view (I'm creating jpegs and then combining them into avi files). Now coming to my actual problem, some objects are overlapping others and when I zoom in it is getting cleared out to some extend not fully. Is it because of my computer graphic problem or should I change any of the settings in Revit software?
And when I open the jpegs or avi files in other computers also I'm having the same problem.
Please see the attachment of my screen shot.
Thanks in advance.
Gelöst! Gehe zur Lösung
Gelöst von cbcarch. Gehe zur Lösung
Yes--this looks like graphics/display problem. What are specs of your GPU and PC?
As a test, try exporting the walkthrough a couple of other ways:
-Shaded or Consistent Colors
-Export as native ( uncompressed) .AVI instead of single frame jpegs.
Also, it could be the frame rate and Codec ( compression ) format being used. This is a bit tricky in Revit.
Take a look here:
Thanks a lot. It did work when I create walk-through in .avi format.
I thought it would be better if I do them as jpegs first. So that when my employer tells some changes, I can replace those particular frames instead of doing the whole walk-through again. It is taking 2 to 3 days to create 6 minutes video. I guess now I have no other choices.
I have attached my PC's specs and .avi video screen shot.
Thank you again for your time.
