Revit Railing in Naviswork looks weird
nurul
nurul
Hi. Railing in Revit looks fine but when import in Naviswork, it offset from the original location & railing become wider. Why is this happening & how to solve this issue?
JM_K
If you don't need an iterative workflow then you might consider exporting the file as an NWC file from Revit then open it in Navis'.
Insert witty comment here.
_Vijay
It look weird....can share sample file for inspection.
