Revit Qusdro or Gtx
15 ANTWORTEN 15
Nachricht 1 von 16
abarbato68
1311 Aufrufe, 15 Antworten
Revit Qusdro or Gtx
revit as other autodesk software want nvidia quadro. but if i should use revit live a gtx. confusion. how many PCs should I buy? gtx work, yes or no, with revit and others?
15 ANTWORTEN 15
Nachricht 2 von 16
als Antwort auf: abarbato68
Nachricht 3 von 16
-FDC-
GTX will work.
Nachricht 4 von 16
abarbato68
GTX will work. in the future or already today? so is gtx 1080 advisable? it is said that Quadro is more accurate in rendering. but gtx is less precise, does it mean quality or can crash?
Nachricht 5 von 16
-FDC-
There are a lot of people here who are working with gtx graphics cards.
I am quite sure gtx will be a good enough.
What kind of work are you doing?
Nachricht 6 von 16
abarbato68
Revit and revit live. Revit live suggests the use of oculus and vive. when i test for my pc, oculus recommends gtx. oculus seems to want a lot of video ram. how can autodesk advise the use of oculus that wants gtx. Not everyone can buy two notebooks :lächelndes_Gesicht_mit_lächelnden_Augen:
Nachricht 7 von 16
-FDC-
Go for the GTX then.
Nachricht 8 von 16
Which exactly is the Quadro you are after?
Nachricht 9 von 16
abarbato68
Quadro for revit live and oculus. But I think is better gtx. But I hope gtx don’t give me problem or crash. I don’t understand the quality of Quadro vs Gtx
Nachricht 10 von 16
-FDC-
To keep it simple let's say that it's a driver thing.
Quadro's have better drivers.
Nachricht 11 von 16
dgorsman
als Antwort auf: -FDC-
Not quite - better to say it's a "math thing".  However the graphic card isn't used for "math" for Revit and Revit Live, so it doesn't matter.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Nachricht 12 von 16
abarbato68
Okay, but translated in more words that means in real life? In practice what does it mean?
Nachricht 13 von 16
abarbato68
als Antwort auf: dgorsman
For revit no. But if I want to continue in revit Live and Oculus and Unreal Engine 4, it is very important.
Nachricht 14 von 16
Again, what is the specific Quadro card that you want to compare?  There are tons of them and they aren't created equal.  They can range from a few hundreds to 7-8 thousands dollars.  A GTX-1080 Ti is about  a tenth of a top Quadro.  Is it going to 10% the performance?  I don't think so.
Nachricht 15 von 16
-FDC-
Unreal is a game engine.
GTX is a gaming card.
If unreal is that important for you.
Go for the gtx.
Since you don't say what GTX you have in mind I think I can recommend a GTX1080 SLI.
Nachricht 16 von 16
We did many tests with Revit and different VR workflows over the last couple of months, which is, what I'm assuming you're after since you mentioned Live and Unreal.
We have so far tested laptops/desktops with GTX 1050,1060,1070,1080 and 1080Ti with Oculus, Vive, Daydream and just for the last two days the Samsung Odyssey for MS MR. Here's my summary: Stay away from the 1050s, the 1060s are OK, the 1070s are good, the 1080 is great and the 1080Ti screams. We have tested them with Revit Live, Unreal, Enscape, Twinmotion and Lumion (7.5). I cannot tell you anything about the Q cards but the GTX 1070 and above work really well.
Marc
