Hello, does anyone know of a add-in that generates qr codes in revit? My goal is to have the qr code be placed on every sheet tying the sheet to a scan number text. I'm looking for something that's automated. Any help would be greatly appreciated. Thanks ๐
Yes, something i can create a view template and have the qr code link to each sheet.
Please see this forum thread on QR codes
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Have a look at this Forum Post:
https://forums.autodesk.com/t5/revit-architecture-forum/qr-code-in-revit-18/td-p/7765233
I read this post a while back and although you can add single QR code then you would have to place it, but this is a bit tedious if you have over 100 sheets per project. Has anyone tried to achieve something like using the api and a visual studio Nugent add in?
@barthbradley Did you have to generate and drag each QR code over? Or was this generated in Revit?
