Is there a way to export a 3D model or the renderings I made so that you can walk through the project in VR, I've made a few 1x12 images that I currently use in a google cardboard, but can I put these together so I can walk through them like Google Maps?
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
@Anonymous hello, you can refer to this LINK previous thread. thanks
These are all plug-ins or with an HTC vive/ oculus rift. I am searching for something that's a bit more simple. We aren't willing to invest in any of those and just have a google cardboard atm and Revit LT.
Hi @Anonymous
3dsMax interactive is a powerful VR engine that gives you the ability to go from Max to VR if you want to consider that workflow in 3dsMax.
See the workflow HERE
Here is an interesting article where the team at Layton construction used the Revit to 3ds Max to Stingray
See a demo below for Revit to VR using Google Cardboard + Modelo
You could also try Immersify* or InsiteVR* or BIM Holoview* I was at an Insite VR demo recently and it seems to work for Revit models.
*I have provided a link to an application or add-in that MIGHT provide the extra functionality for which you are looking. Please note, however, this is not an Autodesk product or endorsement. You should take all precautions whenever you elect to download/install/utilize any application and do so at your own risk. Please review the developer’s documentation and disclaimers before proceeding to utilize their product(s).
Please select the Accept as Solution button if my post solves your issue or answers your question. Kudos welcome!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
