Revit Project Information
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
logan83X8W
1921 Aufrufe, 1 Antwort
Good afternoon, I have a project template that I am setting up for our Firm's new projects moving forward. As part of this we are creating a standard Revit model starting view (a Titleblock family) for when we issue a purged model to consultants etc, I would like to create some additional project information parametres to go on this starting view for provide the consultants with all relevant information that we can fill for each project.
My issue that I'm unable to bring through into project file some of the shared parameters across from the family created, such as Client Address - I've created one in the family but it does not show through in the model - it should be under Client name but it isn't. The goal is to get it to show under Project information when working correctly with the others.
Secondly, would it be easier to just duplicate the Client name parameter for this case - but where do i find this category parameter? - where is the default save path for Revit parameters.
Please refer to pictures for more clarification. Thank you very much.
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: logan83X8W
Create a Project Parameter using the same Shared Parameter. Assign it to the Project Information Category.
