is the Revit professional certification exam, a practical exam, or a theory exam? if it is a theory exam, then what is the point distribution? and what will be the pattern of it? and how many questions will be there? @Alan.johnson1970 @hmunsell
Gelöst! Gehe zur Lösung
Gelöst von mauricio_mssf. Gehe zur Lösung
most of that I can't answer. I can can say it is a Mix of practical knowledge and theory. you will need to know how tasks are done in Revit to answer the questions. I believe it is around 50 question's. id suggest checking the required skill sets section of the link below.
https://www.autodesk.com/certification/all-certifications/revit-architectural-design-professional
Howard Munsell
The Autodesk Design Academi platform has more information and training that can clarify your doubts.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
Mauricio Santos Filho Arquiteto | BIM Manager
Are you asking what is the point of taking the test? None if you don't pass it. But if you do pass it, then you get a badge and bragging rights. Whether or not that badge and boasting will advance your career is unknowable. Can't hurt though. Could give you a leg up in a competitive job market.
thank you , for the information . in a previous post you had , said that the exam was now entirely procedural questions and there is no need to open the software at all. i wanted to clarify if it is true globally .
thank you so much , the link answered all my doubts , I'm really grateful .
the old test was, in my opinion, all right out of the instruction manual questions. Autodesk has been revamping the test the past year or so though. the "new" tests are more real world questions created by professional's in the field. you will need to know how things are done, not just instruction manual examples. i was part of the group that rewrote the Mechanical exam. I think the Architectural one was done last year.
Howard Munsell
Hello there! On March 27 I'll take the Revit Professional exam, based on the new procedure ( just questions exam (no -Revit window-).
1) at the end of the exam, will I immediately receive the final result?
2) how many questions there are in the exam? I understand between 45 and 60, am I right? 120 minutes?
3) What is the minimum score to pass?
Thank you in advance!
