Hi. Every time I try to make a new project this shows up. How may I fix it? Thank you.
Gelöst! Gehe zur Lösung
Gelöst von RobDraw. Gehe zur Lösung
It looks like you didn't get the project templates when the program was installed.
If you download and install them into the default location, then you will have choices.
Thank you. Is there a link that I my use to download this templates? Or should I reinstall Revit? Thank you.
Do you have any defaults listed on the Project Options=>File Locations tab?
@Anonymous wrote:Thank you. Is there a link that I my use to download this templates? Or should I reinstall Revit? Thank you.
Have you verified that the content was not downloaded? It would be a waste of time to do it again if you already have it installed someplace other than the default location. See @barthbradley's response.
Check HERE. thanks
