I'm trying to print a sheet of colored elevations via Bluebeam PDF from Revit, however, one of the elevations consistently has problems where a part of the elevation is filled with the wrong color, despite the lines remaining correct. This only shows up in the actual PDF, it is not visible in either Revit or the print preview. How should i go about fixing this?
I've attached images for reference.
