The first attempt usually does not generate a file, PDF, at all. The screen does flash and shows a progress bar, nut nothing is created. On the second attempt a PDF is usually generated and the progress window shows the sheet count as they are created.
As far as I know, this problem is not yet solved by Autodesk.
What I do is that before printing, I click preview then print after that.
That way it works.
Mostafa Elashmawy
