Revit Point Cloud Transparency Issue: Hidden Lines Not Working
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
youssef.ibrahimM37J6
262 Aufrufe, 4 Antworten
I'm using Revit to work with point clouds, and I'm facing an issue where the point clouds appear transparent even though the visibility style is set to 'Hidden Lines.
Does anyone have experience with this issue? Are there any specific troubleshooting steps or known solutions that I can try?
4 ANTWORTEN 4
Nachricht 2 von 5
It’s possible that the issue is related to how the point cloud was scanned. Points may not be visible in areas where the surface wasn't adequately illuminated during scanning.
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 3 von 5
Doesn't look that abnormal to me.  But maybe changing the color mode would make it easier for you.
https://help.autodesk.com/view/RVT/2025/ENU/?guid=GUID-6340F92E-D2A5-49CC-A8B3-25D65090A325
Nachricht 4 von 5
Point Cloud as the name shows consists in a multitude of Points with coordinate (X,Y,Z) and color information . No Meshes ( surfaces)
Now, if you look from distance ,it looks like colored surfaces , but when Zooming In you'll see the Points as entities and you'll see also the background.
So, the densities of Points will allow more or less to see the background
Constantin Stroescu
Nachricht 5 von 5
thank you all for the support, i appreciate it, it seem it depended on the point cloud quality
