Revit Perspective view
sheema
Observer Observer
sheema
Observer
Observer
Hi
I am getting this strange problem in Revit where the perspective view is very distorted.
Distorted where the internal stuff like kitchen sink, doors etc is protruding out of the external wall in perspective view, but appears correct/ normal in elevation or the 3D view.
I am trying to work out what is causing this
I have attached examples
cbcarch
Check a couple of things:
1. See if you have any Cad files in the project. If so, and their Origin is located more than 20 miles away from Revit's Origin, it can cause these problems.
2. Check you graphics card driver, and see if it needs to be updated.
3. Under the "R" in the upper left corner of your screen, select Options, then Graphics, and try either turning On or Off Hardware Acelleration.
4. Create another camera view, and see if has the same dispaly problems. If so, double-check the items above. If not, it could be that the camera view
has become corrupt. If so, just re-create it with a new camera view.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
sheema
Observer
Observer
HI Thanks alot.
You were correct. My model was miles away from Revit origin. After shifting it closer to the oriigin the perspective view is  showing correctly. Thanks alot.
