Revit Perspective 3D Line Showing Up
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
samye228
269 Aufrufe, 3 Antworten
I have two issues with two different perspectives. The first is a line is showing running under the bar stools.
I've looked at the floor plan and the floor is one continuous object. Can someone tell me how I could go about finding this line?
The second issue is a shared wall was created, one side is the bedroom, the other is the great room. The wall appears to have a cutout and the properties say it is a structural rebar cover.
samye228_1-1666288281059.png'
If I delete the cutout then I get an error concerning rooms, which I understand but why did the wall not heal itself? How can I remove the wall opening?
3 ANTWORTEN 3
Nachricht 2 von 4
Reed_Weinstock
als Antwort auf: samye228
@samye228 Any chance you couple upload the model? I can take a look at.
Nachricht 3 von 4
Line: click on it and see what it is.  I think it may be a room separation line.
Nachricht 4 von 4
samye228
als Antwort auf: ToanDN
I wasn't able to click on it but I hid Room Separation lines and that worked. Thank you very much.
