Revit .pat files not recognized
22 REPLIES 22
Message 1 of 23
Kev_D
3909 Views, 22 Replies
When trying to load a .pat file, I get the following error.
When I check the filepath, the .pat files icon is different. I am thinking this is why it is not loading.
The icon should look like these
Any idea why this is happening?
22 REPLIES 22
Message 2 of 23
in reply to: Kev_D
Message 3 of 23
Kev_D
in reply to: ToanDN
But even at that, they still should have the right icon in my directory. Without trying to load from Revit, when I navigate to the filepath folder in my C Drive, the icon is not the correct one.
Message 4 of 23
in reply to: Kev_D
The icon means nothing. If the .pat extension is somehow associated with another program then the files will show with that icon of such program. You can just right click and open it in Notepad to see the content.
Message 5 of 23
in reply to: Kev_D
Open the .pat file and change %%Drafting%% to %%Model%% and then Save it under a new name.  Then see if you can create a new Model Pattern from it in Revit.  Might work. Might not.
Message 6 of 23
Pattycake_Kyle
in reply to: Kev_D
In addition to potentially not being a PAT file or the right type in general, that is also the error output when there is also something internally wrong with the PAT file. (lines too dense, spacing or offset non-compliance etc - it wont even load the PAT file into the program). Which as @ToanDN has pointed out, the icon doesn't matter. It looks like its correctly saved as a .pat file.
If you upload or copy in the text here for that PAT file i can investigate for you. Or head over to Pattycake and paste in the values in our text editor, it will pop out a red '!' for which lines may be issues.
Cheers
Error on line 14Error on line 14
www.pattycake.io
Web based & real time .PAT creator. The largest collection of free PAT files! Over 700+ Pat files ready to download
No plugins or add-ins to install, and Revit compliant!
Message 7 of 23
hmunsell
in reply to: Kev_D
the reason your seeing the way you are is the ".PAT" file type has been associated with Notepad.
  • right click on the file
    • Open With
      • Choose another App
        • and pick the application you want to associate the .PAT file with.
That said, a .pat file is just a text file, you can open and edit it with any text editor.
Howard Munsell
Message 8 of 23
Kev_D
in reply to: ToanDN
OK. Thanks for the clarification. This was the first thing that jumped out at me cause I always remember the .pat file being the 'red' icon in the image above. Now I know. I will have to look further to see what the issue is. At least that is ruled out.
Message 9 of 23
Kev_D
in reply to: Pattycake_Kyle
This is great. Thank you for pointing it out.
Message 10 of 23
Kev_D
in reply to: Kev_D
Still getting the error after using Pattycake to create the .pat file.
Copied it into a .txt and renamed to .pat
When creating and new Model pattern, I navigate to this .pat and I still get the error
Message 11 of 23
Pattycake_Kyle
in reply to: Kev_D
See the error on line 8?
The "!" tells you something is wrong there. If you hover over that icon, it will tell you more specifically about the error.
In this case i can tell you its that your offset is set to zero (0). The offset tells it how to repeat the line, and if that is zero, there is no 'repeating'. So for DRAFTING patterns (for example), Autodesk wants an offset of .002" or more.
This goes into the offset and values for what they do.
https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/Au...
Once you clear all line errors, you should be able to load it in.
www.pattycake.io
Message 12 of 23
Kev_D
Thank you @Pattycake_Kyle
Pattycake has made a serious difference in understanding pattern files
Message 13 of 23
Pattycake_Kyle
in reply to: Kev_D
So glad to hear 😎
Reach out anytime hi@pattycake.io if you are having troubles. And keep an eye out, we're prepping to release some great doc resources for help in creating pattern files and understand them more.
Cheers! :birthday_cake::birthday_cake::birthday_cake::birthday_cake::birthday_cake::birthday_cake::birthday_cake:
www.pattycake.io
Message 14 of 23
erichr
in reply to: Kev_D
Hi, I'm wondering why this is so insanely difficult. Literally none of these steps work for me, Revit won't recognize pattern files even if I reassign how they open with windows, the whole thing is beyond frustrating.
Message 15 of 23
Pattycake_Kyle
in reply to: erichr
Anymore info on what is going on? Suggest you load it into Pattycake and it can normally spot the errors. As earlier mentioned in the thread, it wont matter what program its assigned to. It normally has to do with the PAT file breaking one of the many rules or incorrect syntax. If you load into Pattycake, you'll see red ! mark for errors and when downloading, it will give you warnings for potentially 'bad' PAT files.
https://pattycake.io/docs/d/pat-file-syntax-and-rules Check here for the rules, the file most likely has incorrect syntax or is breaking a rule, both of which wont load into Revit. You can also reach out to hi at pattycake if you need additional help 🤘
www.pattycake.io
Message 16 of 23
erichr
Ok, pattycake spotted possible errors but I have no idea about how to fix them.
Also Revit can't even find the file to load the pattern, so that's still an issue.
Message 17 of 23
erichr
in reply to: erichr
Also the pattern file seems to have been vetted by Revit City users, but I have not once been able to successfully load any .pat file into Revit. So there seems to be some major problem with Revit not finding the file type, I'm not sure though.
Message 18 of 23
hmunsell
in reply to: erichr
can you upload the PAT file to this thread so we can take a look at it?
Howard Munsell
Message 19 of 23
Pattycake_Kyle
in reply to: erichr
Ditto to what @hmunsell said. We have to see the PAT file to take a look and test it. Or perhaps link to the revitcity thread?
www.pattycake.io
Message 20 of 23
erichr
in reply to: erichr
I now think that perhaps the problem is with .pat files that I'm getting from Revit City. I managed to find a .pat file generated just for Revit that seems to work. Thanks for the help.
As far as editing these files, I'm not sure where to start, maybe with a tutorial?
Forma Design Contest
