Revit parameter formula if and
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
esvitasheva
694 Aufrufe, 3 Antworten
Hi everyone,
I am trying to set up formula which will give me few options for total height ( I need 6 options)
I found IF AND formula the best, but it works perfect only with one condition AND
if(and([Рама 34/59], [Створка 48/33]), 92 мм, 0 мм)
I need something like this! but it doesnt workS:
total height = if(and([Рама 34/59], [Створка 48/33]), 92 мм, if (and([Рама 34/59], [Створка 50/41]), 100 мм, 0 мм, if (and([Рама 44/69], [Створка 50/41]), 110 мм, 0 мм)))
Beschriftungen (2)
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: esvitasheva
Conditional statements can contain numeric values, numeric parameter names, and Yes/No parameters.
Revit Formulas for "everyday" usage (revitforum.org)
...are you receiving an inconsistent units error?
Revit - Inconsistent Units and how to neutralize them. (revitforum.org)
Try this:
 if(and([Рама 34/59], [Створка 48/33]), 92 мм, if (and([Рама 34/59], [Створка 50/41]), 100 мм, if (and([Рама 44/69], [Створка 50/41]), 110 мм, 0 мм)))
Nachricht 3 von 4
Nachricht 4 von 4
esvitasheva
als Antwort auf: barthbradley
Thank you! It works!
