Revit Options - HOW copy/paste elements from DO1 to DO 2
panizBMS2M
panizBMS2M
I already have 2 design options, and I want to copy some walls from design option 1 to 2, but when I click  on "add to set", is shows me this error! Any idea how I can copy some elements between DOs?
Why don't you Clipboard Copy and Paste Aligned to Same Place between DOs?  Not use Add to Set.
panizBMS2M
Because after doing that, I still can't copy or add it to the other DO!
Is the DO you are pasting into open in editing mode?
panizBMS2M
YOU ARE A GENUES! Thank you so much!
