All,
It has been few days that when I want to open another project in Revit it will open in "separate windows" meaning that I can't copy-paste items..or even import families in projects...
I appreciate your help.
Thank you,
Amir
You need to re-associate the file extension .rvt with the right Revit.exe. Usually Done via the registry; however, if you are not familiar with that, you can try if the following works
(Even if they are already associated with Revit, re-associate them)
If the above doesn't work, you will need to
If you are not familiar with editing the registry, it would be best if you ask an IT specialist to assist you with that
You should always open projects from within Revit. This is especially important when you have more than one version installed.
You cannot copy/paste or transfer project standards from two different instances of Revit. You need to open BOTH files within ONE Revit window, then you can do the copy/paste or transfer project standards.
